Are you using the imagery or the feature layer version?
One way you can solve this is by using blend modes in Map Viewer. Here is a sample I tossed together using the imagery version and I removed the not mapped values under layer styling:
I created this clipped area by have these three operational layers grouped in a group layer and in this order
Then on the TX_state layer I set the blend mode to destination Atop under the layer properties panel
and then you are set.
It will also work for the feature layer version. Here I applied a bloom and a drop shadow to the FL version to make it pop against the imagery layer.
