I have created seven Arcade expressions in order to customize a pop up on a hosted feature layer in ArcGIS Online.
Each expression uses IIF to create the text I want to appear in the popup.
Example: if the feature has an attribute trainassist = 'yes', I have the text in the popup say "Training and Assistance"
so my expression consists of:
IIf($feature.TrainingAssist=="yes", "Training and Assistance", " ")
if that same feature has a second attribute combat = 'yes', I have the text in the popup say "Combat"
IIf($feature.Combat=="yes", "Combat", " ")
There are a total of seven attributes that I do this for. If an attribute doesn't have "yes", I don't want any text to appear, so the else is just " ".
The trouble happens when I create the custom pop up using the Custom Attribute Display.
Simply listing the expressions one after the other results in empty lines in the popup (the else " ") when the condition of 'yes' is not met.
I've tried building one combined expression with IsEmpty, and making an array variable, but I am stuck.
I've attached another graphic which goes into further detail.
Thank you in advance for any help!
