Yes, or share the web map that you are using. Web Maps create a specific schema when accessing layers. If the underlying data is updated, sometimes the web map is unaware of the changes and doesn't submit calls to the new layers or features. In order to verify if this is the issue, i suggest looking at the specific web map.
If you add the map service to a new web map, does the new data appear?
-Kelly
