Hi Cameron - I don't think ESRI has any plans to add this as an enhancement. WAB/3.X will be retired in the next year. You can add the "reorderPopupFeatures" and "sortFeatures" functions shown below to the PopupManager.js file that is bundled with the web appbuilder source code. Make sure to add "this.reorderPopupFeatures();" at the end of the init function. The example below (also attached) is the entire PopupManager.js file that gets bundled with WAB. It's from version 2.19.
FYI - I believe ESRI runs an identify operation by service to get the popup features when the user clicks on the map. All of those identify requests are done asynchronously and there is no guarantee what order they come back in. ESRI could run all of that synchronously but that could create lag/bottlenecks. The example presented in this response simply sorts the features array by layer order.
// Copyright © Esri. All Rights Reserved.
// Licensed under the Apache License Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
define([
'dojo/_base/declare',
'dojo/_base/lang',
'dojo/_base/html',
'dojo/topic',
'dojo/on',
'dojo/query',
'./FeatureActionManager',
'./utils',
'./dijit/FeatureActionPopupMenu',
'./RelatedRecordsPopupProjector',
'dojo/_base/array',
'dojo/promise/all',
'dojo/Deferred',
'dojo/aspect',
'./LayerStructure'], function(declare, lang, html, topic, on, query, FeatureActionManager,
jimuUtils, PopupMenu, RelatedRecordsPopupProjector,array, all, Deferred, aspect, LayerStructure) {
var instance = null;
var clazz = declare(null, {
mapManager: null,
// popupUnion = {
// mobile: is mobile popup of map,
// bigScreen: is popup of map
popupUnion: null,
_relatedRecordsPopupProjector: null,
constructor: function(options) {
lang.mixin(this, options);
this.popupMenu = PopupMenu.getInstance();
this.isInited = false;
this.featureActionManager = FeatureActionManager.getInstance();
topic.subscribe("mapLoaded", lang.hitch(this, this.onMapLoadedOrChanged));
topic.subscribe("mapChanged", lang.hitch(this, this.onMapLoadedOrChanged));
topic.subscribe("appConfigChanged", lang.hitch(this, this._onAppConfigChanged));
topic.subscribe("widgetsActionsRegistered", lang.hitch(this, this._onWidgetsActionsRegistered));
init: function() {
this.popupUnion = this.mapManager.getMapInfoWindow();
if(!this.popupUnion.bigScreen || !this.popupUnion.mobile ||
!this.popupUnion.bigScreen.domNode || !this.popupUnion.mobile.domNode){
return;
if(!this.isInited){
this._createPopupMenuButton();
this._bindSelectionChangeEvent();
this.isInited = true;
reorderPopupFeatures: function() {
var that = this;
this.layerStructrue = LayerStructure.getInstance();
// intercept the popup.setFeatures method, reorder feautres and recall original popup.setFeatures method.
aspect.around(this.popupUnion.bigScreen, "setFeatures", function(originalSetFeatures) {
return function(featuresArg, options) {
var convertedFeatureDefs = [];
// having to consider that there are two categories of features parameter can be received.
// 1, feature array
// 2, deferred array
array.forEach(featuresArg, function(featureOrDef) {
if(featureOrDef.declaredClass === "esri.Graphic") {
// it is a feature
var def = new Deferred();
def.resolve([featureOrDef]);
convertedFeatureDefs.push(def);
} else {
// it is a deferred
convertedFeatureDefs.push(featureOrDef);
this.clearFeatures();
all(convertedFeatureDefs).then(lang.hitch(this, function(results) {
var features = [];
array.forEach(results, function(result) {
array.forEach(result, function(feature) {
if(feature) {
// remove duplicated features
var featureAlreadyExist = array.some(features, function(f) {
if(feature === f) {
return true;
} else {
return false;
if(!featureAlreadyExist) {
features.push(feature);
}, this);
// sort features by layers order.
var orderedFeatures = that.sortFeatures(features);
// recall origin setFeatures.
originalSetFeatures.apply(this, [orderedFeatures, options]);
// js-api will using options.closetFirst paramether to show popup by default when clicking the map.
// this paramether will impact features order, so having to deny it.
// that means the closeFirst parameter will never tack effect for show popup in the WAB environment.
aspect.around(this.popupUnion.bigScreen, 'show', function(originalShow) {
return function(location/*, options*/) {
originalShow.apply(this, [location, false]);
aspect.around(this.popupUnion.mobile, 'show', function(originalShow) {
// accordiing to layers order to sort features
sortFeatures: function(features) {
if(!this.layerOrderPriority) {
// according to layers order to define a priority object, using to sort features.
this.layerOrderPriority = {};
var priority = 1;
this.layerStructrue.traversal(lang.hitch(this, function(layerNode) {
this.layerOrderPriority[layerNode.id] = priority++;
// update this.layerOrderPriority if the layer structure has been changed.
if(!this.layerStructureChangeHandler) {
this.layerStructureChangeHandler = this.layerStructrue.on('structure-change', lang.hitch(this, function() {
this.layerOrderPriority = null;
array.forEach(features, function(feature) {
if(feature && feature.getLayer) {
feature._priority = this.layerOrderPriority[feature.getLayer().id];
} else {
feature._priority = 100000;
}, this);
// features.sort(function(featureA, featureB) {
// return featureA._priority > featureB._priority;
if(featureA._priority > featureB._priority)
{ return 1;}
else
{ return -1;}
return 0;
return features;
_createPopupMenuButton: function(){
if(this.popupMenuButtonDesktop) {
html.destroy(this.popupMenuButtonDesktop);
if(this.popupMenuButtonMobile) {
html.destroy(this.popupMenuButtonMobile);
this.popupMenuButtonDesktop = html.create('span', {
'class': 'popup-menu-button'
}, query(".actionList", this.popupUnion.bigScreen.domNode)[0]);
var mobileActionListNode =
query("div.esriMobileInfoView.esriMobilePopupInfoView .esriMobileInfoViewItem").parent()[0];
var mobileViewItem = html.create('div', {
'class': 'esriMobileInfoViewItem'
}, mobileActionListNode);
this.popupMenuButtonMobile = html.create('span', {
}, mobileViewItem);
on(this.popupMenuButtonMobile, 'click', lang.hitch(this, this._onPopupMenuButtonClick));
on(this.popupMenuButtonDesktop, 'click', lang.hitch(this, this._onPopupMenuButtonClick));
_onPopupMenuButtonClick: function(evt){
var position = html.position(evt.target);
if(this.menuActionsOfSelectedFeature) {
this.popupMenu.setActions(this.menuActionsOfSelectedFeature);
this.popupMenu.show(position);
_bindSelectionChangeEvent: function(){
on(this.popupUnion.bigScreen, "show,selection-change", lang.hitch(this, this._onSelectionChange));
on(this.popupUnion.mobile, "show,selection-change", lang.hitch(this, this._onSelectionChange));
_onSelectionChange: function(evt){
this.selectedFeature = evt.target.getSelectedFeature();
//this.selectedFeature = this.mapManager.map.infoWindow.getSelectedFeature();
if(!this.selectedFeature){
this._disablePopupMenu();
return;
node = dojo.query("[dojoattachpoint=\"_title\"]", this.popupUnion.bigScreen.domNode)[0];
node2 = dojo.query("[dojoattachpoint=\"_description\"]", this.popupUnion.bigScreen.domNode)[0];
this.initPopupMenu([this.selectedFeature]);
var selectedFeatureLayer = this.selectedFeature.getLayer();
var hasInfoTemplate = this.selectedFeature.infoTemplate ||
(selectedFeatureLayer && selectedFeatureLayer.infoTemplate);
if(hasInfoTemplate) {
//this._createRelatedRecordsPopupProjector(this.selectedFeature);
_disablePopupMenu: function() {
html.addClass(this.popupMenuButtonDesktop, 'disabled');
html.addClass(this.popupMenuButtonMobile, 'disabled');
_enablePopupMenu: function() {
html.removeClass(this.popupMenuButtonDesktop, 'disabled');
html.removeClass(this.popupMenuButtonMobile, 'disabled');
// public method, can be called from outside.
initPopupMenu: function(features){
if(!features) {
this.popupMenu.setActions([]);
return;
var featureSet = jimuUtils.toFeatureSet(features);
this.featureActionManager.getSupportedActions(featureSet).then(lang.hitch(this, function(actions){
var excludeActions = ['ZoomTo', 'ShowPopup', 'Flash', 'ExportToCSV',
'ExportToFeatureCollection', 'ExportToGeoJSON', 'ShowRelatedRecords',
'SaveToMyContent', 'CreateLayer'];
var popupActions = actions.filter(lang.hitch(this, function(action){
return excludeActions.indexOf(action.name) < 0 ;
if(popupActions.length === 0){
}else{
this._enablePopupMenu();
var menuActions = popupActions.map(lang.hitch(this, function(action){
//action.data = jimuUtils.toFeatureSet(feature);
action.data = featureSet;
return action;
this.menuActionsOfSelectedFeature = menuActions;
this.popupMenu.setActions(menuActions);
* Events
onMapLoadedOrChanged: function() {
this.init();
_onAppConfigChanged: function() {
if(this.popupUnion) {
if(this.popupUnion.bigScreen && this.popupUnion.bigScreen.hide) {
this.popupUnion.bigScreen.hide();
this.popupMenu.hide();
if(this.popupUnion.mobile && this.popupUnion.mobile.hide) {
this.popupUnion.mobile.hide();
_onWidgetsActionsRegistered: function(){
//to init actions
this.init();
* Methods for show related records
_createRelatedRecordsPopupProjector: function(selectedFeature) {
try {
if(this._relatedRecordsPopupProjector &&
this._relatedRecordsPopupProjector.domNode) {
this._relatedRecordsPopupProjector.destroy();
this._relatedRecordsPopupProjector = null;
//var refDomNode = query(".esriViewPopup", this.popupUnion.bigScreen.domNode)[0];
this._relatedRecordsPopupProjector = new RelatedRecordsPopupProjector({
originalFeature: selectedFeature,
//refDomNode: refDomNode,
popup: this.mapManager.map.infoWindow,
popupManager: this
} catch(err) {
console.warn(err.message);
clazz.getInstance = function(mapManager) {
if (instance === null) {
instance = new clazz({
mapManager: mapManager
return instance;
return clazz;
