I am using ArcGIS Online to create a map that will be used to view project locations (Primary Point TEST) that fall within a larger polygon (Chinook ESU Boundary). The project points come from a REST (end point) service that was made into a feature layer (not hosted) via the URL. The polygon layer is a single large polygon that was originally a shapefile published from ArcGIS Pro to my AGOL account.
I've tried this process with the point layer being a hosted feature layer, but it does not update automatically as projects are created/removed. It is static and I'm looking for it to be dynamic.
The main goal is to ensure that the points layer is still updated as project points are added to/removed from the rest service. Additionally, as new points are added into the REST service, we want those to be also filtered by the Chinook ESU polygon so project points outside of the polygon do not show on the map.
The current polygon layer (blue):
Example of points we would want on the map (highlighted green with check mark) and those we don't want to show on the map (flagged red with 'x').
Thank you so much for helping!!
