Hub Content Tags
1016
6
07-19-2021 01:31 PM
RoscoPeters17
I'm having some difficulty adding a web service to my hub. I've copied the url and input the required fields but it seems like the "Tag*" is not being accepted. I've tried creating a new tag and making sure that the entry matched existing tags but neither seems to work. Please advise:
ReubenWeinshilboum
I think that you just need to press Enter on your keyboard once you've typed the tag, or word. The ArcGIS Hub Metadata Tags will accept the asterisk "*" (see below); however, I can't think of many cases when this would be necessary.
ArcGIS Hub Metadata TagsArcGIS Hub Metadata Tags
ReeseFacendini
Remove the "*" from the beginning of the the tag name.
ReubenWeinshilboum
OvidioRiveraAllianceB-C
That worked. Sorry, it seems very basic...
Hello Roscopeters, I'm new at ArcGis Hub and I have that same problem, did you have some solution?
Thanks.
CharlottePeters95540
You need to press the ENTER key after each tag to commit the tag. If you're using the TAB key to go to the next field, the tag(s) will not be accepted.
massitchy
Do you know how to fix this problem? I'm a newbie here at ArcGis Hub and I'm having the same issue.   thirdle
