My presentation will not show the map notes as they appear in the slides, I lose the bounding box and background, each note is strung right accross the screen.
I am on Windows 7, and the same fault happens in Chrome Firefox and IE9. The only way I see the Map Notes correctly is when viewing the slides in ArcGIS Explorer Online, or starting the presentation from there (so it runs in Silverlight).
Any help would be appreciated because - yep, you guessed it - I need to make a presentation of this material on Wednesday.
I have attached a view of the good and bad representations of my notes. Every note was based on a 'feature template' that I had created.
Is there any solution or workaround to this feature?
You've encountered a limitation of the ArcGIS.com map viewer. Background colors and text wrapping are not currently supported. Only ArcGIS Explorer Online supports this currently.
