Map Notes
3004
11-24-2015 09:40 AM
MargaretRobinson
Repost message:
"Is there a way to control which map note symbols show up in the legend of a web map?  I want to create a polygon area map note, and have just the area symbol show up in the legend.  Instead, the legend shows all sorts of symbols (stick pin, push pin, cross, text, lines and areas, even though I'm not using them. Seems like it should only show the map note symbols I'm actually using right?
Ben"
I am having this same problem.
Margaret
KyleBalke__GISP
Occasional Contributor III
The only solution I know of is to save the map notes layer as a feature collection and then publish the feature collection as a hosted feature service.  Add the hosted feature service to your map and you can then modify the style to remove or hide the symbols you are not using and do not want to display in the legend.
Best,
Kyle
