Hi
I have added the maps and apps gallery to my content from the AGOL configurable apps. I have configured the gallery to present users with documents they have access to through group membership.
I have found that the app more often than not fails to get any items. I have determined that the http://<AGOL Org url>/sharing/rest/search?num=100&start=0&sortField=title&sortOrder=desc&q=(<group json>)... request is sometimes passing a token parameter and value (which returns items) but most of the time it does not have a token parameter , in which case it fails.
Is this just a configuration issue or a bug?
If it is a configuration issue, can I correct the issue through the templates configuration capabilities or do I have to download the source and host the gallery in my own environment? The gallery is only intended to be used within the AGOL organisation, so I wouldn't think I would publish it back to the AGOl configurable apps.
Mark
