I am having problems today creating new feature service layers both from ArcGIS Pro through the Share/Publish Web Layer and directly in ArcGIS Online. The layers and service gets created but it cannot be added to a new map.
I have tested this will just basic/default configuration. Is there something wrong with ArcGIS Online right now?
Called tech support and for anyone with the same problem the solution was to clear Chrome's cache.
Awesome! Glad you got it resolved! I was going to suggest using incognito mode to load the map/add the service because that's worked for me in the past.
