New Map Viewer - Arcade Labeling and Field Configuration
601
07-06-2021 10:17 AM
ABishop
MVP Regular Contributor
I have an issue with not being able to configure the field to show the comma separators and the dollar sign on a value that is supposed to be formatted as currency.  In the map viewer classic, I was able to change the field format to show the comma separators and also add a dollar sign to the front of the value.  In the new map viewer it is proving impossible.  See attached word document with screen capture pictures.
Amanda Bishop, GISP
RussRoberts
Esri Notable Contributor
Can you try? Text($feature["fieldname"], '$#,###')
RussRoberts
ABishop
worked perfectly!  Thank you @RussRoberts
Amanda Bishop, GISP
