New Map Viewer Set Default Extent
7236
11
07-22-2021 08:28 AM
GraceAnneIngham
New Contributor II
I set the extent of my map under my Map Settings, but cannot figure out how to get the extent that I created to be used as the default when the map is loaded (i.e. if you click the home icon).
MKF62
I understand you want to set the extent at a very specific set of coordinates so your solution to editing the JSON is the best at the moment, but for those who come across this thread that want a particular view, but maybe don't need anything precise (i.e. eyeballing is good enough), you can create a bookmark. Then you can click the bookmark before you save to ensure the map saves at the appropriate extent (essentially it becomes your new home button).
Sleigh86
This is very helpful! Thank you!
