Querying a Joined Table
Ran across this thread with the same issue I was having with the Javascript API - appears to be an issue with using MSD files and using joins from a data tables that is in a different locations than the feature class. My .mxd works, but when I tried to use an .msd file I started getting this error. Switched back to using an .mxd. I'm on 9.3.1 still, so this may be resolved with 10. Anyone know?
The error is described here:
http://support.esri.com/en/bugs/nimbus/TklNMDQ1MjU5
