Overwrite Feature Service to webmap does not update with new data
1751
06-02-2017 01:58 PM
Lake_Worth_BeachAdmin
Occasional Contributor III
I have a web feature service on a web map and then shared through an web app.
This service is just a small point layer and I update it every month with updated points. I then upload the layer to agol using the "overwrite" option on my existing point feature service. However my web map does not update with the new points automatically. I have to re-add the service as a new layer and remove the previous one in addition to manually copying my pop-up configs over to the new layer.
I was under the impression the overwriting the service would in turn have the updates roll out to the web map layer. What am I missing here?agol webmap feature service error
I found out that I needed to set my refresh interval for the layer properties. problem solved.
