When I use the "Overwrite Web Layer" tool in ArcPro, it successfully overwrites my web layer. But when I open a map that uses the web layer, it messes up the layers.
For example:
The Parcel Layer is symbolized hollow with a white outline.
The Watersheds are symbolized hollow with a thick green outline.
After updating, the legend looks correct, but when you look at the map, the parcels are symbolized as the watersheds and vice versa.
Again everything appears correct in the legend, but it's incorrect on the map. Why is this happening? What's the point of overwriting the web layer if it's going to mess up every single map that uses the web layer?
The map I'm using was initially created maybe 2 or more years ago. I just created a copy, did the overwrite, and everything appears correctly. Again though, I don't understand why this would make a difference.
