pop-up configuration - show image?
1007
04-11-2018 12:27 PM
MorganFrazier
New Contributor II
My issue is that I am trying to get my photo to appear in the popup. I configured the pop up with the url & it is a photo saved on my flicker with the privacy settings to public. Instead of the image I get this symbol (below) and if I click it it opens my flicker album. pop-up configuration #Image
Symbol instead of image
KellyGerrow
Esri Frequent Contributor
Hi Morgan,
I was able to get this working by adding the direct link to the jpg that was provided in the BB Code:
http://farm1.staticflickr.com/808/41393062671_cc9908c84f_z.jpg
Here is my copy of your map:
https://arcg.is/1vzrfr
I'd suggest unsharing the layers or disabling editing if this is going to be shared publicly.
Let me know if this solves the issue.
-Kelly
MorganFrazier
New Contributor II
Not comments.................I am still stuck trying to configure the pop-ups to include an image, any advice would be warmly received as I need to share this and I can't figure this configuration out.
I have tried
1. flickr share:
Path through the Oak woodlands Photo by Maura O'Brian | Flickr
2. flickr embed: (This is the string to embed the thumbnail sized photo from flickr)
 <a data-flickr-embed="true" href="https://www.flickr.com/photos/32936858@N02/41393062671/in/album-72157667695059848/" title="Path through the Oak woodlands Photo by Maura O&#x27;Brian"><img src="https://farm1.staticflickr.com/808/41393062671_cc9908c84f_t.jpg" width="100" height="67" alt="Path through the Oak woodlands Photo by Maura O&#x27;Brian"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
3.BB CODE: (This is the string for the thumbnail sized photo from flickr)
Path through the Oak woodlands Photo by Maura O&#x27;Brian by [url=https://www.flickr.com/photos/32936858@N02/]NWVINOVIXEN[/url], on Flickr
KellyGerrow
HI Morgan,
Are you able to share your webmap?
Are you loading your web map over http or https?
-Kelly
MorganFrazier
New Contributor II
Hi Kelly,
http://arcg.is/1TKXOb
I made it public if you click on the large circle that says Cathlapotle Village you will see the pop-up.
As for the second question, I am using it in a story map so I am unsure whether that is a http or https?
Thanks so much for taking a look!
Morgan
KellyGerrow
Hi Morgan,
-Kelly
MorganFrazier
New Contributor II
Thank you! That did it, I tried so many combinations and I didn't even see this string in the BB Code. The map was private until I shared it with you but I will keep those things in mind.
