Problem sharing a feature service using 10.2 with arcgis online organizational accoun
2316
10-06-2013 04:30 PM
MarieEsten
I have been trying to publish map services using 10.2 desktop following the instructions provided on the ESRI help sites (ie: File->share as-> service).  The process seems clear enough, I check and fix any errors and then select the "preview data" button in the dialog and everything looks fine.  I am able to upload the data and have no errors.  Then when I try and access the data in the online organizational account the feature service is completely empty!  Does anyone have any insight into this issue?
Thank you in advance
Marie
by Anonymous User
Not applicable
Hi Marie,
Can you share a link to the service or Service Definition?
Andrew
MirBBenesov
by Anonymous User
Not applicable
Hi Miroslav,
I could not reproduce this issue with your map. It returned 230 features and appears to render as expected.
[ATTACH=CONFIG]28272[/ATTACH]
Cheers,
Andrew
MirBBenesov
Yes, I know. The problem was concerning with my basemap, which was not available from external server.
Thank you.
