I have a base map from ESRI showing a road in North Citrus County Florida that should end. However it does not and connects to a road that it should not connect too. The Road is N. Fauci Pt. and should end at private property. Landowner is having trespass issue due to this.
Should be like this on your openstreetmap open source map.
Landowner would appreciate a fix to this.
