Hi @XanderBakker The rotation of labels is simple in ArcGIS Pro and even with Arcade the appearance can be manipulated but all this effort is useless after publishing to AGOL you left with plain labels.
Publishing to a tile layer is not an option because the dataset contains multiple records. And after publishing to AGOL the hosted feature layer is used in a joined view to visualize a projectplanning with time slider.
In ArcGIS Pro 2.8.3
I show highways and which lanes are closed. With an arcade expression I can give the label multiple colors related to an attribute. And the position of the label is perpendicular repeated and aligned based on the direction of the polyline. I this situation it is important that the polylines have the same direction of the traffic flow.
In ArcGIS Online
Classic Viewer
- the arcade expression in not accepted. So why Arcade in ArcGIS pro is different from AGOL?
- in classic viewer the label can be aligned but very basic: Above, On or Below the polyline
Map Viewer
- labels can cannot be aligned anymore?
