Hi Kelly: Somehow I missed your response from November. Sorry for my delay.
I do have a very basic question just to make sure I understand the issue and what can be done:
If you publish a tiled & cached image service, can that same image service be setup to dynamic deliver imagery for layers that the mxd supports but that are not Cached in the Image Service?
I think that is the basic question being discussed in this thread? Or have I misinterpreted things.
Wouldn't be the first time. 😉
And the other basic question, if the answer above is Yes, does this apply to Portal and ArcGIS 10.5 Image Servers
I may not have explained my issue properly.
Basically, I am trying to get a locally published Image Service, which is now on a dedicated 10.5 ImageServer, that is cached and tiled down to Level 19 (counting from Level 0) This is a 1:500 Scale.
So in other words, I added one more level beyond the "stock" 19 levels.
When this layer is active, if I zoom in closer than the 1:500 scale, my locally published imagery stops displaying.
It will only display at levels for which I created the cache.
The Esri Imagery basemaps keep on displaying for as long as I can zoom in.
It seems obvious that the Esri imagery basemaps are resampling down below ~1:1000
(I would guess that is the actual resolution of the imagery.)
I want to get our Tiled/Cached Imagery to do behave like this.
I'll cache it down to the source resolution and then let it resample down below that.
so far, I think all the info on this thread has been related to AGOL and not Portal.
I believe your response below to Kalen but with the URL adapted for Portal is the info I need?
But I am missing something on getting to the rest admin site for our new 10.5 Image Server.
I can go here:
https://MyFQDN/MyWAName/rest/admin/
and not pull an error. But I only get a 98% blank page.
all I see is the following:
When I try to go to the specific tiled service's rest admin point, for example:
https://MyFQDN/MyWAName/rest/admin/services/Aerials_2016_StatePlane/ImageServer/edit
I pull a 400 error, Invalid URL
I've tried a few things to add in tile info to URL but so far no luck.
Thanks for you help!
