Do you need to add this as a wms service or can you use the map server endpoint?
This url loads fine in map viewer, but we automatically use the map server url endpoint when it's available with ArcGIS Server based services which this is. You can add the WMS endpoint as an item using this url:
I receive an error message, but the item loads just fine. I'll get the team to look into why an error is received, but as a best practice, I would recommend using the map server endpoint when its available.
-Kelly
