WAB Dev 2.5: service sublayer visibility settings not honored in 3-d apps
926
07-20-2017 02:48 PM
BarnabyRockwell
In WAB Dev 2.5, map service sublayer visibility settings are not honored in 3-d apps. Sublayers set to be off (invisible) by default in mxd prior to publishing are on by default in WD 2.5 3-d apps.  My services were published using Server 10.5.
This was not the case for WD 2.4. Using same services and Web Scene, visibility settings as set in mxd are honored in 3-d apps made using WD 2.4.
Hopefully I am wrong about this, but it looks this way. Can anyone confirm this?
If true, is this behavior by design?
BarnabyRockwell
BUG-000102949: SceneView now honors parent layer visibility when working with sublayers.
Release notes for 4.4 | ArcGIS API for JavaScript 4.4
????  Yikes.  Robert Scheitlin says this is a known bug in JS 4.4 API.
BarnabyRockwell
BarnabyRockwell
This issue has been fixed in WAB 2.6 for AGOL (Sept. 2017) and in WAB Dev Edition 2.6 (Oct. 2017).
