Currently in ArcGIS Pro 2.5.2, you must enter a radius value as one of the values for a curve. I would like to see the ability to choose any combination like the traverse tool in ArcMap.
When you change the arc length/chord length/delta angle drop down in the tool, the units available in the grid are not immediately updated. You have to start a new traverse for the change to take place. For instance, when you change to "Delta Angle", the units will still show ft/mi/etc.
Additionally, could we have an option to set default units. I typically see delta angles as degrees/minutes/seconds and not decimal degrees but the traverse tool does not save the units preference.
