Good day,
When you need to create a "open parcel", you need to send all the lines to the ConnectionLine instead of the parcel type. It would be nice to have a function that would help us.
This would be similar to CopyLineFeaturesToParcelType, but without the polygon layer.
It seems that CopyLineFeaturesToParcelType does some clean up when copying the lines. It would be nice to have the same behavior when doing a CopyLineFeaturesToConnectionLine...
For example, the CopyLineFeaturesToParcelType doesn't seem to copy lines that have zero length.
The only extra parameter I would had is if the copied lines should be "broken" in each segments or not.
