Access to Closest Facility location service
1119
11-16-2022 04:05 PM
maglourenco
New Contributor III
Greetings everyone,
I tried to run a Closest Facility task using the Closest Facility location service from ArcGIS.
It did not succeed and returned the following error:
Spoiler
Closest facility task failed to load: java.io.IOException: The API key `*4O6gt` is invalid, expired, or does not have access to the resource: `https://route-api.arcgis.com/arcgis/rest/services/World/ClosestFacility/NAServer/ClosestFacility_Wor...`. Please visit https://developers.arcgis.com/api-keys to configure the API key to access the resource, or to create a new API key.
I went to check my account privileges. I have an ArcGIS for Developers account with an Essential plan. According to my account details, I have access to the ArcGIS Location services, which include the Routing service. However, I noticed that the Closest Facility service scope was 'pay-as-you-go'.
Thus my question is: do I need to enable the pay-as-you-go billing to use the ClosestFacility ArcGIS location service, or am I missing something?
Thank you.
Cheers
rsands
by Esri Contributor
@maglourenco you are correct. In order to use the Closest Facilities location service with a developer essentials plan, you must enable billing on your plan.
With a Developer Essentials account, you can use any of the location services with that have a free tier, up to the limit of that service's free tier. Any service that does not have a free tier, including Closest facilities, can only be accessed once billing is added.
DiveshGoyal
This would be better in the ArcGIS Platform questions space
rsands
by Esri Contributor
maglourenco
New Contributor III
Thank you very much for the clarification! Cheers
JaredFaulk
New Contributor III
is this also the case for a the Professional Developer subscription? I am trying to access closest facility but am not getting results back. If we must enable billing, how do I  use my Esri Portal credits? Thanks.
