Add Advanced ArcMapSetings.exe to the Arcmap or Arc Catalog will be appreciated.
Bcoz to edit or make a custom changes to ArcMap, one has to go in search for the exe inside the directories.
Instead of doing that, if we create a seperate tool or a submenu inside the Tools Menu will reduce the work of customizing arcmap. The user can easily change the interface settings in Arcmap, on the go. That is from being in the arcmap itself.
I think this would be appreciated by more people.
