When adding a "double" field type in ArcGIS Pro, please allow precision and scale to be defined if using an enterprise geodatabase.
For example: if I add a double field to an enterprise geodatabase dataset, the precision and scale can not be defined when adding the field(s) through the Pro interface, and this results in them being 38,8. In most of our use cases this far exceeds any precision and scale we'd use and bloats the table. If I want to alter the precision and scale, I have to manually do it through the database interface like SSMS.
