ArcGIS Pro - Editing Date Attribute
1555
07-24-2017 12:12 PM
Status: Implemented
Kenny_Ratliff
New Contributor III
In experimenting with editing attribution, I've come across this hindrance.  ArcMap editing allows me to tab through the fields, upon arriving at a date field, I'm able to hit Enter and populate with today's (current) date and time.  In ArcGIS Pro - not only can I not use the Enter button, but the selection for Today's Date is a "dead link".  In other words, I'm not able to select with the mouse.  This many times requires moving from keyboard entry to mouse and back.
Requesting the Today's Date option be enabled for mouse selection and tab entry with keyboard.
Thanks!
3 Comments
JenniferCadkin
I am testing editing of dates in the Attributes pane and the Feature Template Active Template pane in ArcGIS Pro 2.5.  When tabbing through the Attribute grid, click either the up or down arrow on keyboard to set a date field to the current date and time, and then click Enter key to apply.
Hopefully this helps.
-Jennifer
Scott_Harris
Scott_Harris
At 2.7, a new calendar control was added that allows navigating the calendar, as well as setting the date (including current date) by using the just keyboard.
At 3.0, we improved this a bit by allowing entry into the calendar control using the keyboard. To do this: while in a date field, hit TAB to give focus to the calendar control and spacebar to open the calendar.
