Click on a Cluster and Show List of Individual Point Features
681
03-30-2022 02:24 PM
Status: Open
PatrickKent1
New Contributor III
Is there a way to do point clustering in Pro so that you can still click on a cluster and see a list of all the features contained in it? this capability exists in Web Map Viewer in the form of a button to "Browse Features" in the cluster popup window. It is even more robust in the WAB widget called InfoSummary which allows you to click on a cluster and see all of the clustered points spatially. But this capability does not seem be possible in Pro.
3 Comments
DanPatterson
In Pro, Select Layer By Location (Data Management)—ArcGIS Pro | Documentation
a little more work, a lot more control
so no  auto-select
ZihanSong
Hi Patrick,
This functionality is not currently available at this point, but we are hoping to make it available in a future release.
For all users, please add your vote in this so we can have better evaluation of this idea.
Zihan
Gerald_Daumiller
When you click on a clustered feature symbol with the Identify tool (ArcGIS Pro 3.1.2), it only shows you the number of features in the cluster, which is not helpful at all - the symbol already tells you the number of features.
The identify tool should give you a list of the features, the same as when you click on a clump of non-clustered points.
The last time I looked, Binned data worked the same way, and I believe that should also be changed.
Thanks!
