Create or Import New Legend Patch Shape
2415
29
12-08-2020 02:04 PM
Status: Under Consideration
JustinRego
New Contributor II
In ArcMap I was able to create a new patch shape for the legend. This was a tool from Customize the tool bar called New Legend Patch Shape. It no longer appears available in Pro. This level of customization is critical for my mapping efforts and I would love to regain access to this tool!
29 Comments
AlvisDou
This is a very important tool for us and I am incredibly anxious for it to be implemented on the Pro soon. There is a detailed guidence for the New Legend Patch Shape tool in ArcMap: https://www.esri.com/arcgis-blog/products/arcgis-desktop/mapping/new-legend-patch-shapes/?rmedium=bl...
We really need it!
KatiePiper
It would be nice if Esri could develop a way to change the legend patch to accurately reflect layer blends. When there is a hillshade with a layer blend, the color of the map and the color of the patch on the legend do not match. It would be nice if you could use a tool similar to Eyedropper but "clip" a section of the map to replace the legend patch.
This could be applied to fills as well. If you fill your polygon with dots, triangles, squares, etc. and have them large, you can't see them represented in the patch.
AlvisDou
it has been half a year passed away, I still not see this function came back.
CRose
I also would really value having this capability. I am working on a series of geologic maps, and would like the features in my legend to more closely resemble the features in the map area. If I could have one more shape, I would like a diagonal line that's somewhat curved (not straight) for line features. But ideally, I would like to upload my own shapes, just like the "New Legend Patch Shape" tool allowed in ArcMap.
Wayne_Rennick
Another vote for this feature.
I did some training recently and they said that ArcGIS Pro had reached parity with ArcMap. But I keep finding things I can't do.
Maybe John Nelson can explain how we can replicate this feature.
KoryKramer
@Wayne_Rennick make sure to Kudo the idea.
DGFa10_Nord_du_Quebec
Hi, I just learned this possibility with 10.4.1 but it doesn't want to work for me. Everything appears to be unaccessible (in light gray) for some reason.
Does anyone know why or how to solve this situation ?
Thank you
JustinRego
This is only blank for me when there is nothing in the ToC. Add some layers to you MXD and select some geometry, then the tool will populate.
@JustinRego
I actually did have some layers in the ToC. I think the problem was with my projected coordinate system. For some reason the tool doesn't recognize some of them.
Thank you for your help.
jcokin1
Please add another vote for this feature.
Was in a discussion with ESRI reps and they also said that ArcGIS Pro had reached parity with ArcMap (lol)...this is not true as we continue to find features that are missing such as this one.
https://support.esri.com/en-us/products/arcmap/life-cycle
ArcMap retires on March of 2026.
Share this idea within your colleagues and do not forget to comment below for ESRI.
