I'm working with a dataset that I didn't make and I really only care about a few fields but don't want to delete the ones I am not interested in in case they come into play. However, there are issues with the domain and I don't really have the time to investigate nor do I care to fix it right now. However, this warning that covers the entire upper part of the pane pops up every single time I click, select, or edit, even if I've hit the X for that particular selection - extremely annoying especially on a laptop screen. Tried 'hiding' the fields from the fields view and that doesn't work either, seems to only hide them from attribute table. This should be dismissable for the entire session, thanks.
