It would be great if the output parameters for 3D were copacetic with the list of available ArcGIS Pro 3D inputs:
3DS —3D Studio Max
WRL —VRML or GeoVRML
SKP —SketchUp 6.0
FLT —OpenFlight
DAE —Collada
Or update ArcGIS Pro to be able to read:
OBJ (default)—OBJ file with the following:
X,Y,Z position for each vertex of the 3D textured mesh
Texture information (using .jpg and .mtl texture files)
Zipped OBJ—ZIP file containing the OBJ, .jpg, and .mtl files
FBX—FBX file with the following:
Texture information
AutoCAD DXF—DXF file with the following:
PLY—PLY file
I know City Engine can work with OBJ, but this doesn't help those who do not have City Engine.
I also know that ArcGIS Pro can consume the scene layer once its been published to ArcGIS Online.
This is already offered via the Import 3D Files Tool
https://pro.arcgis.com/en/pro-app/tool-reference/3d-analyst/import-3d-files.htm
