Having built-in polygon outline styles in ArcGIS Pro
3213
9
03-09-2018 11:49 PM
Status: Implemented
GergelySzalay2
New Contributor III
It is nice and comfortable in ArcGIS Desktop to have a predefined built-in set of polygon outline styles when one would like to simply and quickly differenciate some polygons from others by their outline styles. Also, it is useful to have a similar built.-in style, when just minor adjustments should be made on it to meet your needs.
This is more useful, when one would like to use complex composite outline style using style layers.
Alas, this possibility is missing in ArcGIS Pro and I would appreciate to have it in the coming versions!
9 Comments
KoryKramer
GergelySzalay2
Yes, it is.
MattSmith6
Yes please, I've only started using Pro in the same way as Desktop quite recently and this is a major bugbear.
If you have two layers that you want to symbolise in the same way (eg. Coastline & Water Polygon) it's near impossible if you have a line style with any great complexity
圈圈
这是我最希望ArcGIS Pro增加的功能,明明在Arcmap中早就有的功能
JamalNUMAN
Yes, please we need this enhancement
KeithAddison1
Recreating linetypes manually is getting old after a year of Pro.  Hope this gets implemented.
MatDunford
This is junk. I don't need a big pink blob on my aerial photo. I need customizable boundaries. I might have a county boundary, a watershed boundary, a unit boundary, property lines....I'm supposed to do all this with a color and a dash effect?
I need the line symbols available for polygon boundaries or a lot more pre-built options
PegGronemeyer1
Yes, Please!  Add my vote to this.  Why would we want to create our own outline boundary when _usually_ the provided options in ArcMap were sufficient?
Found potential work around if  you save the standard ArcMap symbols as a style with a dif name than the default, it will be stored in your style file.  You may have to search for it, (generally it is called your user name.style).  It's actually quite easy to import an ArcMap style into Pro.  (https://www.esri.com/arcgis-blog/products/mapping/mapping/importing-older-styles-into-arcgis-pro/#:~....)  Just be sure to select "all styles" instead of project styles in the symbology window that opens in Pro when you double click on a symbol in the TOC.  Hope that helps.
Peg
AmeliaBradshaw
This Idea has been implemented in ArcGIS Pro 3.1. You can now add a line symbol style as a polygon outline style using the 'Import layers from a symbol' option, as described in the Symbol Structure documentation. Please see the What's New documentation for more new features in Pro 3.1.
The Ideas in ArcGIS Pro 3.1 blog will be wrapped up soon, highlighting all Ideas implemented in this release, including this one. Once complete, I will add the link to this comment.
