When exporting data in ArcMap, the prompt below is displayed.
In ArcPro, this prompt is not displayed. Instead, you can change the settings for exporting data in Project > Options > Geoprocessing (see below). By checking or unchecking the box, any exported data for the project is either always added or never added to the map.
However, in my work, I sometimes want an export to be added to the map, while another export I do not want added to the map. It just depends on the task in the project.
I recommend that a prompt be added to ArcPro, like that in ArcMap, however, this prompt could be optional, by checking or unchecking a box in settings. It could read: “Display prompt asking to add exported data to the map as a layer”. If this box is unchecked, than the user would have to check or uncheck the box that is currently in Pro: “Add output datasets to an open map”.
