Save/Persist table settings (field order, sorting) in Interactive Rematch window (geocoding review)
429
10-20-2016 08:02 AM
Status: Open
AZendel
Occasional Contributor III
The fastest way for me to review imperfect geocode scores is to arrange the columns in a particular order and then sort on two columns.  This customization takes a considerable amount of time.  It's frustrating to see this time go down the toilet when I:
1) close and then reopen Interactive Rematch window
2) click the 'Refresh Button'
3) change the results set
4) restart ArcMap.  Since ArcMap has the propensity to crash, restarting ArcMap is sometimes beyond my control.
I just tried the Interactive Review panel in ArcGIS Pro.  Seriously lacking!, but that's for a different Idea/Topic.  I've read that Pro 1.4 is supposed to have a lot of "ArcMap equivalencies".  Lets hope that a feature rich Interactive Rematch window is included ... and that it persists column order and sorts.
2 Comments
Lake_Worth_BeachAdmin
Yes!!!!!
Seriously Esri you need to implement this.
I need to constantly add new fields to attribute tables and would like to place these new fields next to pre-existing fields not have it stored at the very end (far right). When I rearrange the columns nothing is saved after I close the application. The table defaults back to its original column order.
This cant be that hard to implement.
wayfaringrob
@Lake_Worth_BeachAdmin  - I know this is quite old, but I just stumbled upon this - perhaps you couldn't at the time, but if you head to the fields view, you can rearrange the order of the fields from there. Simply drag the row by the row's header up or down, save, close.
