I recently converted our parcel data to the parcel fabric. At no point in the conversion process are you warned about Bezier curves. I wasn't even aware my parcel data contained them or even how they were introduced into the parcels.
They break the parcel fabric. Almost any interaction with a parcel fabric feature that contains them will lead to software freezes, crashes, or bugs. I verified this by manually converting them all to true curves and retrying the same processes that produced these issues and they worked like a charm once the bezier curves were gone. Currently, there is no easy way to identify bezier curves and there is no way to remove them short of manually converting each segment, one-by-one. When you are dealing with more than 100k features, this is obviously not practical. I would propose two things.
The parcel fabric documentation should be updated to mention that bezier curves are not supported. It should also document a procedure for removing them from your data prior to converting to the fabric.
There should also be a software function for finding them and converting them to true curves. That way, if you are already in the fabric, you can at least track them down and fix them rather than stumble upon them unexpectedly.
