I'm making a map in ArcGis Pro 2.1 .
In this map I want to display Lables with 2 lines (The ID above, a description/name underneath). The 2 lines-label is not a problem, within VB or Arcade I found the option for creating a multi-line label.
But the problem is I want them to be centre-aligned, but when I want to check the option for Centre Alignment in the Lable Class settings I see the 3 options for Horizontal Alignment being grayed out. So i can't change the horizontal alignment of my labels.
What am I doing wrong, do I need to change a setting or is this a known bug in 2.1?
