No matter what I do it just gives me this error below. I have tried just about everything. The only thing I can think of is perhaps this will not work with AGOL hosted tables? The target layer is in an AGOL relationship class tables while the append layer is just in AGOL feature set tables. I have also attempted to use a local file geodatabase table as the append class but I get the same error.
File "S:\GISDataActive\ParcelMap\AutomatedUpdates\Appendaddress.py", line 24, in <module>
append_layer = arcpy.management.MakeFeatureLayer(append_class, "append_layer", where_clause)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 9395, in MakeFeatureLayer
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 9392, in MakeFeatureLayer
retval = convertArcObjectToPythonObject(gp.MakeFeatureLayer_management(*gp_fixargs((in_features, out_layer, where_clause, workspace, field_info), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset https://services2.arcgis.com/wEula7SYiezXcdRv/arcgis/rest/services/Parcel_Updates/FeatureServer/1 does not exist or is not supported
Failed to execute (MakeFeatureLayer).
Failed script AddressAppend...
Failed to execute (AddressAppend).
