ArcGIS Pro 2.5: “pivot” tool ends up with incorrect result,
1033
9
06-22-2020 12:53 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why “pivot” tool ends up with incorrect result.
Is this a bug?
In ArcMap, this is successfully performed using the same data (attached)
Jamal Numan
DanPatterson
MVP Esteemed Contributor
Looks like a bug, I would zip and ship to Tech Support
... sort of retired...
JamalNUMAN
is this fixed in 2.6?
Jamal Numan
DanPatterson
Release notes for ArcGIS Pro 2.6—ArcGIS Pro | Documentation
You will have to look through the release notes yourself
JamalNUMAN
Nothing in the list related to pivot
Jamal Numan
DanPatterson
Maybe it wasn't reported as a bug, so nothing got addressed.
There is always next year
Robert_LeClair
Esri Notable Contributor
Jamal - thank you for providing the gdb.zip file for testing.  I was able to get the Pivot Table GP tool to work by adding a new field REF_G2 (as a short integer vs a long integer (what you have).  Then I calculated the new REF_G2 using the old REF_G column.  From there, I ran the Pivot Table GP tool using the same parameters you have in your screen grab.  The result is the same as ArcMap as seen in the image below.  Seems the long integer field type is the issue - not sure why.
BBicking1
Hello Jamal,
I repro-ed the issue in 2.7_25974 and logged an issue for it to get fixed.
We had a similar issue in AGPro way back that was data-specific. May be the same in this case.
NOTE: If the fix makes it into a 2.6 patch, I'll let you know.
Thanks for reporting the issue.
Barbara Bicking
BBicking1
Jamal,
a preliminary finding: When Ref_G is the 1st Input Field it works as expected
Please check if that works for you as well.
Still, we will look into the issue.
JamalNUMAN
Correct. If the “Ref_G” field is ordered before the “Name” field in the input fields, then the pivot works fine.
In ArcMap, it works anyway. This confirms that this is a bug
Jamal Numan
