ArcGIS Pro crashes when Applying Layer Symbology from Layer
1841
10-18-2022 03:17 AM
MichaFranz
Whenever I try to apply a layer symbology from a layer file (.lyrx) ArcGIS Pro immediately crashes. This happens with any input feature layer and any layer file. It even happens when I create a layer file from a feature layer and apply it to the same feature layer.
Are there any known issues / solutions for this problem?
Thanks!
ArcGIS Pro Verison: 2.9.3
AlKamuda1
New Contributor II
Would the roll back on the KB's create issue being able to publish new or overwrite web layers in Server / Portal.
George_Thompson
Esri Frequent Contributor
I believe that is the cause of the issue. Till a patch is potentially released.
--- George T.
MichaFranz
Ah I see, thanks for the hint!
