I created a model using Iterate Feature Selection. For each feature selection I use 'If Field Value is' to determine how my points are converted into a line, I then merge these two branches, and collect all the values.
I would like to use this model as a submodel, so that these Output Values can be the input for my next process. However, the model only works in edit mode. When I run this model as a tool (Stand alone or within another model) the feature class from the last iteration is not saved.
