ArcGIS Python API error- 'GIS' object has no attribute 'tools'
3523
03-27-2017 11:50 PM
Durga_D
Getting hands on with latest ArcGIS Python API.Getting below error after running processing sample.
Using Geoprocessing tools | ArcGIS for Developers
from arcgis.gis import GIS
gis = GIS()
map = gis.map()
map
diegogarcia = gis.tools.geocoder.find_best_match("Diego Garcia")
map.center = diegogarcia
AttributeError                            Traceback (most recent call last)<ipython-input-3-cb8f9185cd0a> in <module>()----> 1 diegogarcia = gis.tools.geocoder.find_best_match("Diego Garcia")      2 map.center = diegogarciaAttributeError: 'GIS' object has no attribute 'tools'
I have completed all necessary configurations suggested at Install and set up | ArcGIS for Developers
conda,Jupyter Notebook and upgraded to latest versions.
NeilAyres
Its exactly as the error says, there is no attribute or method with the GIS object for Tools.
arcgis.gis module — arcgis 1.0.1 documentation
You should look at the geocoding module.
arcgis.geocoding module — arcgis 1.0.1 documentation
Durga_D
I have tried geocoding module and it is working fine.
Should I infer that the example provided by ESRI at Using Geoprocessing tools | ArcGIS for Developers  is wrong and get corrected in future ?
JoshuaBixby
MVP Esteemed Contributor
The code isn't wrong, per se, it just isn't accurate for the current version of the API.  The structure of the API has changed fairly significantly over the past 6 months or so.  Unfortunately, Esri has an issue with their URLs for the ArcGIS API for Python.  For example, the 2 URLs goto different pages with different examples:
https://developers.arcgis.com/python/sample-notebooks/Using-Geoprocessing-tools/
https://developers.arcgis.com/python/sample-notebooks/using-geoprocessing-tools/
Notice the capitalization differences.  The URL that is all lowercase has the most current/accurate content.
JoshuaBixby
I just heard back from the ArcGIS API for Python team, the problems URLs have been updated to redirect to the current/accurate URLs.
