Can you set up attribute rules in ArcPro in a traditional versioned SDE SQL Database? If so, do you have to unversion the feature first and re-version it after setup? I set the sequence rule up on the feature class connected as the database owner and it seems like it should work, but it doesn't, so I'm trying to trouble shoot.
When I edit the feature as the owner of the database it simply doesn't do anything, and when i switch to my version it says it can't find the sequence, so tries to run but can't. Any tips appreciated.
