Best free remote desktop program for using ArcGIS Pro at home?
923
11
03-10-2024 06:45 AM
StephScavelli
New Contributor III
What is the best free remote desktop program out there for running ArcGIS Pro on a home set up?
I'm planning to upgrade a desktop computer with the specs to handle ArcGIS Pro then remote access that computer with my laptop.
I am giving TeamViewer a try but wonder if you've found a better free remote desktop solution for a home set up?
Thank you!
MErikReedAugusta
Occasional Contributor III
I just use Windows Remote Desktop for this.  Full disclosure, though: I'm typically only remoting in from another desktop on-site.
I did do a short stint of work-from-home during the latter months of the pandemic, but we were still running Desktop 10.7 at the time, and I didn't do any real heavy processing.
Based on what I did see, though, I would expect it was likely decent enough speed.  My desktop at work was doing the heavy lifting, either way.
BlakeTerhune
MVP Regular Contributor
Same. I've always used built-in Windows Remote Desktop and I've had no complaints. I think there's some better options if you are constantly switching between many RD sessions at once, but for a single session it's perfectly fine. Is there some feature in particular you find lacking?
Robert_LeClair
Esri Notable Contributor
For our Esri Training Instructor-Led online classes, we use Remote Desktop primarily to access student ReadyTech VM's.  Works well!
StephScavelli
New Contributor III
Thanks for sharing @Robert_LeClair . I am so excited to see how easy it is to remote desktop using ArcGIS Pro. This means I can keep my laptop which is a Microsoft Surface Book 2 and instead upgrade the specs on a new desktop, instead of getting a clunky ugly gaming laptop to lug around.
StephScavelli
New Contributor III
Thanks for the reply @BlakeTerhune .
I have to upgrade to Windows 11 Pro to use the Microsoft Remote Desktop that your using and for $100 one-time fee I wonder if it's worth it? Otherwise, TeamViewer is working decent enough and it's free.  The only things is I have to leave my computer at home on with the TeamViewer App open to connect remotely to it.
StephScavelli
New Contributor III
Thanks so much for the reply (and full disclosure.) I'm currently trying out TeamViewer, but I wonder if it's worth upgrading to Windows 11 Pro to be able to use the Microsoft Remote Desktop your using.
BrandonA_CDPH
I have had good results with Citrix Workspace. Virtual Machine did not work out well, but a physical computer remoted into through Citrix Workspace did the trick.
StephScavelli
New Contributor III
Thanks for the reply @BrandonA_CDPH
What didn't work about the Virtual Machine option you put together? It def seems more complicated than a remote desktop to a physical machine.
Why did you choose Citrix Workspace over another remote desktop option? The ratings are bad on the Microsoft App store.
BrandonA_CDPH
Honestly, I was/am workign within the confines of what my work IT department offers, so my choices are made for me.
The Virtual Machine was fine for basic mapping and a little ArcGIS Pro work, but for analysis or more complicated symbology (i.e. the real reason for using Pro), it kept crashing and hanging. It came around to a lack of a dedicated graphics card, so they moved me off the Virtual Machine and to a tower set up with Citrix Workspace.
