Bing Maps in ArcGIS Pro
6939
6
10-07-2015 08:32 AM
LawrenceBall
Hi folks,
Does anyone know how to get Bing basemaps in ArcGIS Pro?
I have a Bing maps key and have put this into ArcGIS Online>Settings hoping it may then be available in Pro, but didn't work.
Any help would be greatly appreciated.
Lawrence
JeremyWright
sorry - hit add reply too soon!
to do this, in your organization create a new group and add the Bing basemap to it.  then under the Settings->Map tab, choose the group including the Bing basemap and check the box for "Share the Esri Default Basemaps to this Group when you click Save" to populate the remaining basemaps.
the next time you log into your org from Pro, you should see the Bing Basemap in the list under the Basemap button.
amroqarrot
Unfortunately, I have absolutely no information to appreciate that I did not get a copy of it after the free period
JeremyWright
now that you've added your Bing Key to your org, you should be able to add the Bing basemap to your map in Pro.  However, you may need to add the Bing Basemap to a group in your org to see it in Pro's basemap gallery.
JeremyWright
BobPerham
Huh?? Organization group? What kind of janky work-around is this?  Is there more official instructions on how to add Bing Hybrid basemap to ArcGIS Pro?
JeremyWright
Bob,
The organization is where your clients connecting to named users (such as the viewers in ArcGIS Online, and ArcGIS Pro, if connected to your ArcGIS Online organization) get their list of basemaps.
This is how the basemaps are populated in clients.  Help topic: Configure map viewer—ArcGIS Online Help | ArcGIS
In Pro, you can also just search in portal->All (in the project pane) for "bing" to find the basemaps and add them, if already licensed.
If you need more help, I'd suggest contacting Esri technical support.
Regards,
Jeremy W.
ANANDC
I recently faced this issue and fixed that.
Register for a bingmaps key
Getting a Bing Maps Key
and place your key in arcgis online--> organisation --> Maps ---> Bing Maps.
Now Ready to go.
