Thanks! That worked, although it did take a bit of work to recreate the whole thing. Later, I went back to the map with the problem, and went into the map properties and, under "General", I changed the background color from no color to white, which fixed the problem. I found it a bit odd, because my recreated project map also had no color as the background, but showed as white.
