Takehiko, your graphic shows you have the login set to a Portal, not an ArcGIS Online login. Although the red box is around the circle, it doesn't look like it is select. Try selecting the other button/option and try logging into your AGOL account again.
That is the first thing to try, and may be the only issue.
