I'm manually editing some polygons and for the polygons that share a common boundary, I need them to have the exact common boundary and I cannot get them to close the gaps.
I've tried using the Align Features tool Modify Features tool reference—ArcGIS Pro | ArcGIS for Desktop but it is not working... Instead of closing the gap, I end up with a bigger gap or only the gap, opposed to removing the gap and having a common boundary as in the rightmost par of the clipping: (different results based whether I start from the left or the right)
PS. I have the Map Topology ENABLED
Any ideas on how to make them share a common boundary?
Solved! Go to Solution.
Hey Hector,
Have you tried the Eliminate tool? It is supposed to close the slivers between polygons. I also found this post here with methods that could be useful for your situation. Hope this helps!
Hi Hector,
I would recommend creating a geodatabase topology. With a topology you can set the cluster tolerance. Any vertices less than the cluster tolerance will snap together.
looks just like the tool I need to use. I just need to figure out how to use it in ArcGIS Pro since it is only available via Python...
Set Cluster Tolerance—Data Management toolbox | ArcGIS for Desktop
Hector, you can still use arcmap for data preparation, you should realize that the transition is in progress
Introduction to editing topology—ArcGIS Pro | ArcGIS for Desktop and there are differences
Hey Hector,
many thanks for your valuable ideas! It got me on the right direction.
I managed to make it a topology layer and then using the Align Edge Align topology edges—ArcGIS Pro | ArcGIS for Desktop tool. Quite magical, but manual, since there are only a few Slivers I needed to get rid of, it was no problem at all.
I inherited layers that divided each county into "Routes". The previous work had no precision and the routes had gaps and overlaps. I tried several different techniques and found the following to be most expeditious and precise. I used the Align Tool, but it removed some curves and precise angles that I had put much time into creating.
Assuming the drawing shows a Northern Polygon and a Southern Polygon being separated by a Road.
Note: for further precision, divided highways and interstates can be used by selecting the North/South or East/West line or create a copy then use Collapse Dual Lines To Centerline Tool to create a single line down the middle for splitting polygons.
