Is it possible yet to create new network datasets in ArcGIS Pro, much as you can via ArcCatalog? I understand that it wasn't possible a year ago, but has anything changed since then? If it is possible, what are the steps? If not, is this a feature that we can expect to see in the near future?
Alternatively, is it possible to make a new dataset via the "Create Template From Network Dataset" and "Create Network Dataset From Template" tools? I'm imagining creating a generic XML template from an existing network via the first tool, then modifying the XML to allow the template to be used to generate a new dataset via the second tool with a completely different set of input features (lines and junctions). Is this possible?
Much appreciated.
-Colin
