Good afternoon.
I have an application that exports a .grd and associated .tab file.
The file contains RF signal levels over and area with four ranges of signal strengths of different colors.
How can this be converted or displayed in Arcgis?
The Grid file displays to a degree. It shows three bands as RGB.
On the map it appears as one color.
I suspect the .tab file is needed for the correct color formatting.
The .grd and .tab import fine into mapinfo.
I would be fine with a .shp file format as well but don't see a conversion tool in Arcgis or Qdis for .grd and associated .tab to a .shp file
regards, David
